HYPEX SMPS3KA400 Switching Power Supply Module 3000W 2x65V
The SMPS3K is a high efficiency switching power supply specifically designed for use with nCore and UcD amplifier modules. Its main features are high efficiency over the entire load range, low form factor, low weight and low EMI emission.
By buying this product you get 31 loyalty points
Reference : 15749
315,00 €tax incl.
262,50 € tax excl.
Shipping date: 24-04-2025.
HYPEX SMPS3KA400
HYPEX SMPS3KA400 Module d'Alimentation à Découpage 3000W 2x65V
The SMPS3K is a high efficiency switching power supply specifically designed for use with nCore and UcD amplifier modules. Its main features are high efficiency over the entire load range, low form factor, low weight and low EMI emission. The SMPS3K also features advanced overcurrent protection that limits the output current in the event of a temporary overload. If the overload persists, the power supply will go into "hiccup" mode until the overload is removed. This feature, combined with large electrolytic capacitors, provides high dynamic power to the connected amplifier. The SMPS3K also features a balanced auxiliary output and a control circuit that can interface directly with UcD / nCore amplifier modules.
Product typeSwitching power supply module
Max power3000W @ 20Hz
Input voltage90-132VAC
180-264VAC
Output votlage2x65VDC
Auxiliary output voltage2x20VDC
Switching frequency100kHz
Dimensions200 x 145 x 55mm
Weight1.5kg
InputPCB Connector
OutputPCB Connector
Output voltage (V)65.0
Output current (A)NC
Input voltage (V)100.0
Input voltage (V)230.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)110.0
Input voltage (V)120.0
Input voltage (V)190.0
Input voltage (V)210.0
Power SupplySMPS
The SMPS3K is a high efficiency switching power supply specifically designed for use with nCore and UcD amplifier modules. Its main features are...
