HYPEX SMPS600N400 Module Switching Power Supply 600W 2x65V
4.0 / 5
Reference : 14069
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-04-2025.
Hypex SMPS600N400
Switching power supply high fidelity audiophile
The SMPS600N400 is a high-efficiency switching power supply. It was specifically designed to power NC400 amplifier modules.
This switching power supply has a compact form-factor, reduced weight (300g) and a very low emission of EMI disturbances. A wide buffer stage composed of electrolytic capacitors ensures excellent responsiveness, ideal for developing the dynamics of the amplifiers.
Integration is very easy thanks to the disponibility of a wiring kit allowing an immediate connection to power two NC400 modules. An isolated auxiliary power supply is also included in the module to facilitate integration with other devices and thus bring new features to the installation as a whole. The circuit is also provided with an automatic voltage selector input to allow  quasi-universal compatibility.
The circuit is equipped with an advanced protection against overcharging. The latter can automatically lower the output voltage in case of overload. This will delay the arrival of hiccups - or even avoid them altogether if the overload is short-lasting.
Dimensions
Input Voltage230 / 115V
automatic detection of the input voltageYes
Output voltage2x65Vdc
Output PowerMax: 650W
@ 20Hz Max: 600W
Dimensions140x85x50mm
Weight300g
Included30cm JST VHR-3N with blue and brown wire.
20cm JST EHR-7 with 7 wires.
20cm Molex 43025-1200 to Molex 43025-1200
Mounting set included.
InputPCB Connector
OutputPCB Connector
Output voltage (V)65.0
Output current (A)NC
Input voltage (V)N/A
Power SupplySMPS
10 années !
je ne noterais pas 5 car il faudrait qu'il dure plus de 10 ans pour mériter la note ! (comme de bon vieux appareil vintage !) cependant je ne peu pas dire de mal sur la qualité de cette alimentation car 10 années s'est pas forcément mauvais pour du découpage ! , voila je passe commande de nouvelles alim après 10 années d'utilisation des ncore 400 , je précise que j'étais équipé des 1er versions et les appareils restais presque tout le temp sous alimenté !
This review has been posted for HYPEX SMPS600N400 Module Switching Power Supply 600W 2x65V
