By buying this product you get 27 loyalty points
Switching Mode Power Supply SMPS 600W 12V 53A
The Mean Well MSP-600 switch mode power supply delivers high power, up to 636W, and is suitable for a wide range of applications. The input voltage range is 85~264VAC and this model, the MSP-600-12, provides 12V output voltage. In addition, the module is equipped with several functions, such as an auxiliary output and a remote ON-OFF function, as well as a complete safety system against overload, overvoltage and overheating.
Product type | Switching mode power supply |
Power | 636W |
Input voltage range | 85~264VAC 120~370VDC |
Input frequency range | 47~63Hz |
Efficiency | 88% |
Output voltage | 12VDC |
Output current | 53A |
Ripple and noise | 150mVp-p |
Protections | Overload (105~135% of rated output power) Over voltage (14.4~16.8VDC) Over temperature |
Dimensions | 218 x 105 x 63.5mm |
Weight | 1.57kg |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | 12.0 |
Output current (A) | 53.0 |
Input voltage (V) | 120.0 |
Input voltage (V) | 260.0 |
Input voltage (V) | 210.0 |
Input voltage (V) | 240.0 |
Input voltage (V) | 110.0 |
Input voltage (V) | 370.0 |
Input voltage (V) | 230.0 |
Input voltage (V) | 220.0 |
Input voltage (V) | 100.0 |
Input voltage (V) | 90.0 |
Power Supply | SMPS |
