MEAN WELL SE-450-48 SMPS Switching Mode Power Supply 48V 9.4A 450W
This Mean Well SE-450-48 SMPS switching mode power supply is capable of delivering 48V and 9.4A, i.e. 450W of power. Its form factor makes it easy to integrate into any DIY project.
Reference : 18664
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 23-04-2025.
MEAN WELL SE-450-48 Switching Mode Power Supply SMPS 48V 9.4A 450W
Photo of SMPS MEAN WELL SE-450-48 switching mode power supply
This Mean Well SE-450-48 SMPS switching mode power supply is capable of delivering 48V and 9.4A, i.e. 450W of power. Its form factor makes it easy to integrate into any DIY project. It uses discrete components and boasts an efficiency of up to 88%. A switch on the side panel lets you select 115V or 230V input voltage. The Mean Well SE-450-48 features protection against short-circuit, overload, overvoltage and overheating. It can resist an overvoltage of 300V AC for 5 seconds. A built-in fan ensures efficient heat dissipation.
MEAN WELL SE-450-48 power supply connector picturePhoto of MEAN WELL SE-450-48 power supply design diagramPhoto of MEAN WELL SE-450-48 power supply form factor
product typeSMPS switching mode power supply
Number of outputs1
Output voltage48V
Output current9.4A
Power output451.2W
Input voltage90V-132V AC
180V-264V AC
254V-370V DC
Input frequency47Hz to 63Hz
Efficiency (Typ.)88%
Leakage current< 2.5mA / 240V AC
Operating temperature-10°C to +60°C
ConnectorsScrew terminals
ProtectionsShort circuit, overload, overvoltage and overheating
Dimensions225 x 124 x 50mm
Weight1.25Kg
ColorSilver
Package1x Mean Well SE-450-48 switching mode power supply module
InputScrew terminals
OutputScrew terminals
Output voltage (V)48.0
Output current (A)9.4
Input voltage (V)120.0
Input voltage (V)100.0
Input voltage (V)115.0
Input voltage (V)130.0
Input voltage (V)200.0
Input voltage (V)180.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)230.0
Input voltage (V)110.0
Input voltage (V)190.0
Input voltage (V)90.0
Input voltage (V)210.0
Input voltage (V)260.0
Input voltage (V)240.0
Power SupplySMPS
This Mean Well SE-450-48 SMPS switching mode power supply is capable of delivering 48V and 9.4A, i.e. 450W of power. Its form factor makes it easy...
