MP-H250S12 SMPS Switching Mode Power Supply Module 250W 12V 20A PFC
This SMPS MP-H250S12 switch-mode power supply module is capable of delivering 12V, 20A current and 250W of power. It is also equipped with a PFC (Power Factor Correction), which enables it to deliver constant voltage and current extremely reliably, with an efficiency rate of over 90%.
Reference : 18110
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 16-04-2025.
MP-H250S12
MP-H250S12 SMPS Switch Mode Power Supply 250W 12V 20A PFC
This SMPS MP-H250S12 switch-mode power supply module is capable of delivering 12V, 20A current and 250W of power. Made from high-quality components, the module is mounted directly on a heat sink, which is itself insulated by a layer of plastic. It accepts a wide input voltage range from 176V to 264V AC. The MP-H250S12 is also equipped with a PFC (Power Factor Correction), which enables it to deliver constant voltage and current extremely reliably, with an efficiency rate of over 90%. A layer of silicone makes this power supply even more efficient,, in addition, the output terminal block has been doubled, enabling two different modules to be powered at the same time. Naturally, this module is equipped with all the necessary protection features, such as overtemperature, overcurrent and overvoltage protection. It is an excellent choice for powering components within a DIY project, for example, an amplifier stage with a chip requiring 12V.
Please note: when powering 2 different modules, the MP-H250S12 will deliver 2x12V voltage, but the current will be shared between the two powered modules, for a maximum total of 20A.
Integrated PFC module
The MP-H250S12 switching power supply features an active PFC (Power Factor Correction) with Mosfet transistor. The PFC enables a first switching step to obtain a continuous, non-out-of-phase current at the power supply input. This has two advantages: first, the power supply's efficiency becomes optimum, with a rate of over 90%, and second, the announced power values will remain as they are, whatever the input voltage to the PFC. For example, this power supply will deliver 250W whether the input voltage is 176V or 264V.
SMPS MP-H250S12 power supply module connectors
1VAC input line
2Neutral input line VAC
3Ground (GND) input VAC
4Negative output -12V
5Positive output +12V
Product typeSwitching mode power supply module
Input voltage176-264VAC
Nominal operating frequency50-60Hz
Operating frequency range47-63Hz
Output voltage and current12V 20A (20CFM)
12V 15A (Air cooling)
Voltage stabilization accuracy±1%
Linear adjustment rate±1%
Load regulation rate±3%
Power250W
Efficiency89/92% (115VAC/230VAC)
Maximum input current2.7A 115VAC
1.7A 230VAC
Operating temperature-25°/+70°
Maximum voltage ripple120mVp-p
Insulation voltage3750VAC
Dimensions126 x 66 x 36mm
Weight365g
Package1x Siliconized switching mode power supply SMPS MP-H250S12
InputScrew terminals
OutputScrew terminals
Output voltage (V)12.0
Output current (A)20.0
Input voltage (V)180.0
Input voltage (V)230.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)260.0
Input voltage (V)190.0
Input voltage (V)210.0
Input voltage (V)240.0
Power SupplySMPS
This SMPS MP-H250S12 switch-mode power supply module is capable of delivering 12V, 20A current and 250W of power. It is...
