MP-H250S19 SMPS Switching Mode Power Supply Module 250W 19V 13A PFC
This SMPS MP-H250S19 switch-mode power supply module is capable of delivering 19V, 13A current and 250W of power. It is also equipped with a PFC (Power Factor Correction), which enables it to deliver constant voltage and current extremely reliably, with an efficiency rate of over 90%.
Reference : 18109
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 25-04-2025.
MP-H250S19
MP-H250S19 SMPS Switch Mode Power Supply 250W 19V 13A PFC
This SMPS MP-H250S19 switch-mode power supply module is capable of delivering 19V, 13A current and 250W of power. Made from high-quality components, the module is mounted directly on a heat sink, which is itself insulated by a layer of plastic. It accepts a wide input voltage range from 176V to 264V AC. The MP-H250S19 is also equipped with a PFC (Power Factor Correction), which enables it to deliver constant voltage and current extremely reliably, with an efficiency rate of over 90%. If required, a variable resistor can be used to adjust the output voltage from 18.5V to 20.4V, in addition, the output terminal block has been doubled, enabling two different modules to be powered at the same time. Naturally, this module is equipped with all the necessary protection features, such as overtemperature, overcurrent and overvoltage protection. It is an excellent choice for powering components within a DIY project, for example, an amplifier stage with a chip requiring 19V.
Please note: when powering 2 different modules, the MP-H250S19 will deliver 2x19V voltage, but the current will be shared between the two powered modules, for a maximum total of 13A.
Integrated PFC module
The MP-H250S19 switching power supply features an active PFC (Power Factor Correction) with Mosfet transistor. The PFC enables a first switching step to obtain a continuous, non-out-of-phase current at the power supply input. This has two advantages: first, the power supply's efficiency becomes optimum, with a rate of over 90%, and second, the announced power values will remain as they are, whatever the input voltage to the PFC. For example, this power supply will deliver 250W whether the input voltage is 176V or 264V.
SMPS MP-H250S19 power supply module connectors
1VAC input line
2Neutral input line VAC
3Ground (GND) input VAC
4Negative output -19V
5Positive output +19V
6Adjustable resistor (18.5V-20.4V)
Product typeSwitching mode power supply module
Input voltage176-264VAC
Nominal operating frequency50-60Hz
Operating frequency range47-63Hz
Output voltage and current19V 13A (20CFM)
19V 9.5A (Air cooling)
Voltage stabilization accuracy±1%
Linear adjustment rate±1%
Load regulation rate±3%
Power250W
Efficiency90/92% (115VAC/230VAC)
Maximum input current2.7A 115VAC
1.7A 230VAC
Operating temperature-25°/+70°
Maximum voltage ripple240mVp-p
Insulation voltage3750VAC
Dimensions126 x 66 x 36mm
Weight365g
Package1x Switching mode power supply SMPS MP-H250S19
InputScrew terminals
OutputScrew terminals
Output voltage (V)19.0
Output current (A)13.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)180.0
Input voltage (V)230.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)260.0
Input voltage (V)190.0
Power SupplySMPS
This SMPS MP-H250S19 switch-mode power supply module is capable of delivering 19V, 13A current and 250W of power. It is...
