Power Supply Module 9V 1.3A 12W
This small power module delivers a voltage of 9V and a current of 1.3A. Ideal for feeding small systems.
Reference : 12483
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 22-04-2025.
MODULE POWER SMPS
9V 1.3A 12W
9v power to climb
This module at reduced format will allow you to obtain an output voltage of 9 VDC 1.3A, to supply systems that do not require a high voltage. Moreover, its design incorporates protection against overcurrent, short circuit and over temperature. The module also filters EMI in order not to degrade the signal.
Connection
Input Voltage - AC85-265V
Output Voltage - DC9V
Frequency47-63Hz
Inrush current10A / 220VAC
Quiescent150mV / 220VAC
Current output1.35A
Power12W
Efficiency83%
Ripple<150mV
Leakage current< 220VAC 5MA
ProtectionsOverload
overvoltage
Short
Temperature
Dimensions67 x 31 x 20mm
Spacing24mm
60mm
InputSolder pad
OutputSolder pad
Output voltage (V)9.0
Output current (A)1.3
Input voltage (V)260.0
Input voltage (V)220.0
Input voltage (V)150.0
Input voltage (V)250.0
Input voltage (V)120.0
Input voltage (V)110.0
Input voltage (V)190.0
Input voltage (V)90.0
Input voltage (V)210.0
Input voltage (V)85.0
Input voltage (V)240.0
Input voltage (V)100.0
Input voltage (V)230.0
Input voltage (V)130.0
Input voltage (V)200.0
Power SupplySMPS
2 reviews
Bloc d'alimentation
Parfait pour remplacer un bloc d'alimentation défectueux. Audiophonics toujours top.
This review has been posted for Power Supply Module 9V 1.3A 12W
alimentation a découpage 9 volts
Petite alimentation très bien réalisée. j'en ai acheté 3 et j'en suis satisfait. Que demander de plus. Bravo
