SMPS300RS Switching Mode Power Supply 300W / 24V
4.8 / 5
Reference : 6196
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 22-04-2025.
xxx
The SMPS300RS switched-mode power supply is an ultra-high-efficiency model capable of delivering 300 Watts of rated power in an extremely compact package.
This power supply is capable of delivering 300W of continuous power and up to 400W peak.
The version supplied is 24V.
The main feature of this power supply is the absence of heat sinks for both the power switches and the rectifier diodes.
The amount of EMI is lower than any conventional power supply, and could be compared to a linear regulated power supply.
Its small size and considerably reduced weight mean that the SMPS300RS can be installed anywhere.
The SMPS300R incorporates overcurrent protection that limits output current to around 130% of maximum peak power, i.e. around 400W. This power supply is suitable for both Class AB and Class D/T amplifiers.
Target applications for this power supply include SAP15 amplifiers or Hypex UCD180 modules.
Download SMPS300RE PDF datasheet
Meaning of the terms R, RE, RS and RXE on SMPS power supplies:
QR, R: SINGLE or DUAL power supplies with classic LLC resonant filter for class A/B or D amplifiers, SMPS R power supplies are characterized by their excellent price/performance ratio.
RE: SMPS power supplies with differential and multiple-voltage resonant-filtered outputs featuring an LLC filter with low-noise EMI filter (with CLC filter on low-ripple output) for high-end class A/B or D/T amplifiers. Ideal replacement for conventional linear power supplies (generally suitable for TA2022, TDA8920, TDA8950, IRS2092 amplifiers).
RS: SMPS power supplies similar to RE, but with resonant filter “Single Rail Output” featuring an LLC filter with low-noise EMI filter (with CLC filter at low ripple output) for high-end class A/B or D/T amplifiers. Ideal replacement for conventional linear power supplies.
RXE: The top-of-the-range SMPS 600, 800W and 2000W featuring the latest-generation LLC resonant filters (with CLC filter on low-ripple output) with high-end FET transistors. Specially recommended for high-end Class D amplifiers (IRS2092, HYPEX, CXD). Also suitable for conventional Class A/B amplifiers.
Features :
  • High-efficiency power supply
  • Choice of input voltage
  • Surprisingly compact
  • Low electromagnetic radiation (EMI)
  • Advanced protection
  • 24V output voltage
Specifications :
  • Input Voltage Ranges: 190-250V (Mains 220V)
  • Maximum Power : 400Watts
  • Nominal Power : 300 Watts
  • Dimensions: 100x100x36
  • Weight : 230 g
InputScrew terminals
OutputPCB Connector
Output voltage (V)24.0
Output current (A)NC
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)120.0
Input voltage (V)100.0
Input voltage (V)190.0
Input voltage (V)130.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)95.0
Input voltage (V)230.0
Input voltage (V)110.0
Power SupplySMPS
9 reviews
J'ai commandé une 36 v pas une 24 v
This review has been posted for SMPS300RS Switching Mode Power Supply 300W / 24V
The best 24v smps I have ever owned.
60-80mV is NOT ultra low noise/ripple but with more filtering i could get it to 2-3mV and that is the best result i ever had with a smps.
Powering a Burson Funk, it really makes a difference. It's like the Burson SuperCharger but without the background noise and without the exagerated price. A minor issue is the input filtering choke that is flapping around and it really needs a bit of glue.
Excellent module SMPS300RS
Faibles parasites EMI, faible encombrement, si la fiabilité est comparable aux SMPS 500 et 600 on est proche de l'optimum
Makes a big difference for DIY Boards
I bought this for an ARYLIC UP2STREAM AMP 2.1 Amplifier Module diy project. Previously I had the board connected to a 19V 4.5A brick from an old PC and the sound was very thin for a satisfactory music experience. Once I connected the SMPS300RS wow! Robust sound levels with no sweat from this power supply, it doesn't even get hot, not at all. No hum noise whatsoever, everything sounds impeccable and drives effortlessly any small diy amplifier board. Highly recommended, the 4 stars due to the build quality of the of the copper winding of coils which is not at par with the rest of the board.
Excellent pour class D
Couplé à un SA300, à une paire de Klipsch RP et un caisson, la différence dans le spectre des basses fréquences est flagrante, reste trop cher pour une alim mais l'effet wahou est bien réel.
