SMPS600RXE Power supply Module 600W +/-45V
Reference : 10189
125,00 €tax incl.
104,17 € tax excl.
Shipping date: 16-04-2025.
The SMPS600RXE switched-mode power supply is a very high efficiency model capable of developing a rated power of 600 Watts in an extremely small footprint.
This power supply is capable of delivering 600W continuous power and up to 800W peak power.
The version delivered is a +/- 45 V.
The main feature of this power supply is the absence of heat sinks for both power switches and rectifier diodes.
The amount of EMI is less than any conventional power supply, and could be compared to a linear regulated power supply.
The SMPS600RXE incorporates overcurrent protection that limits the output current to about 130% of the maximum peak power, or about 650W.
This power supply is suitable for both class AB and class D /T amplifiers.
Meaning of the terms R, RE, RS and RXE on SMPS power supplies :
QR, R: SINGLE or DUAL power supplies with classic LLC resonance filter for class A/B or D amplifiers, SMPS R power supplies are characterised by their price/performance ratio.
RE: SMPS power supplies with differential and multiple voltage resonant filter outputs including LLC filter with low noise EMI filter (with CLC filter at low ripple output) for high-end amplifiers in class A/B or D/T. An advantageous replacement for conventional linear power supplies (generally suitable for TA2022, TDA8920, TDA8950, IRS2092,).
RS: SMPS power supplies close to RE but with "Single Rail Output" resonant filter including LLC filter with low noise EMI filter (with CLC filter at low ripple output) for high-end class A/B or D/T amplifiers. Advantageously replaces conventional linear power supplies.
RXE: The top of the range SMPS 600, 800W and 2000W featuring the latest generation LLC resonant filters (with CLC filter at low ripple output) with high-end FET transistors. Specially recommended for high-end class D amplifiers (IRS2092, HYPEX, CXD). May also be suitable for classic class A/B amplifiers.
Features:
  • Very high efficiency power supply
  • Amazing compactness
  • Low EMI electromagnetic radiation
  • Advanced protection
  • Output voltage +/-45V
  • Auxiliary output 15V 500mA
Specifications :
  • Input Voltage Ranges: 190-230V (220V Mains)
  • Maximum Power: 800Watts
  • Nominal Power: 600 Watts
  • Dimensions :100x100x40
  • Weight: 378 g
InputScrew terminals
OutputPCB Connector
Output voltage (V)45.0
Output voltage (V)15.0
Output current (A)NC
Input voltage (V)190.0
Input voltage (V)210.0
Input voltage (V)230.0
Input voltage (V)200.0
Input voltage (V)220.0
Power SupplySMPS
