SMPS600RXE Switching Power Supply Module 600W +/- 72V
Reference : 8533
125,00 €tax incl.
104,17 € tax excl.
The SMPS600RXE switched mode power supply is a very high efficiency model capable of developing a nominal power of 600 Watts in an extremely small footprint.
This power supply is capable of delivering 600W of continuous power and up to 800W peak.
Can be configured for double output voltage from +/- 45V to +/- 72V (on request).
The delivered version is a +/- 72 V.
The available output voltages are adjustable to approx. +5 -5%.
The main feature of this power supply is the lack of radiators for both power switches and rectifier diodes.
The amount of EMI is less than any conventional power supply, and could be compared to a linear regulated power supply.
The SMPS600RXE incorporates overcurrent protection that limits the output current to approximately 130% of peak power peak, about 650W.
This power supply is suitable for both Class AB and Class D / T amplifiers.
Meaning of terms R, RE, RS and RXE on SMPS power supplies:
QR, R: SINGLE or DUAL power supplies with classical resonance filter LLC for amplifiers in class A / B or D, SMPS R are characterized by their ratio qualities price.
REFrom:SMPS power supplies with differential outputs and multiple voltage resonant filters with an LLC filter with low noise EMI filter (with low ripple CLC filter) for class A / B or D / T amplifiers. Conveniently replaces conventional linear power supplies. (Generally suitable for TA2022, TDA8920, TDA8950, IRS2092 amplifiers)
RS: SMPS power supplies close to the RE but with a single rail output with a resonant filter including an LLC filter with low noise EMI filter (with low ripple CLC filter) for class A / B or D / T amplifiers . Advantageously replaces conventional linear power supplies.
RXE: The high-end SMPS 600, 800W and 2000W featuring the latest generation LLC resonant filters (with low-ripple CLC filter) with high-end FET transistors. Especially recommended for Class D high-end amplifiers (IRS2092, HYPEX, CXD). Can also be used for class A / B amplifiers.
Features:/ Strong>
  • Food at very high efficiency
  • Amazing Compactness
  • Low electromagnetic radiation EMI
  • Advanced Protection
  • Output voltage adjustable + 5% -5% (+/- 72V)
  • Auxiliary Output 20V 500 mA (Pin 5 : Out -20V / Pin 4 : GND / Pin 3 : Out +20V)
Specifications:
  • Input Voltage Ranges: 190-250V (On Sector 220V)
  • Max Power Rating: 800watts
  • Rated Power: 600watts
  • Dimensions: 100x100x40
  • Weight: 378 g
InputScrew terminals
OutputPCB Connector
Output voltage (V)20.0
Output voltage (V)72.0
Output current (A)NC
Input voltage (V)230.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)190.0
Input voltage (V)210.0
Input voltage (V)240.0
Power SupplySMPS
