Switching Power Supply Module 700W +/-60V
This LLC switch mode power supply module has a main output delivering ±60V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A.
4.0 / 5
Reference : 15595
49,90 €tax incl.
41,58 € tax excl.
Module d'alimentation
Alimentation à découpage 700W ±60V
Module d'alimentation à découpage 700W ±30V
The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A. The latter allow the supply of less demanding devices, such as a fan. The module accepts an input voltage of 200-240V AC.
The module also benefits from a protection system against overheating, overcurrent and short circuits.
If a protection system is activated, the module locks up. It is then necessary to disconnect the AC power supply and wait for the filter capacitor voltage to drop to 0V before restarting.
The current of the independent and auxiliary outputs cannot exceed the current delivered by the main output.
Product typeSwitching power supply
Input200-240VAC on screw terminals
Output voltagesMain output : ±60V 6.5A
Independant output: 12V 0.5A
Auxiliary output : ±12V 0.5A
Accuracy of voltage stabilization±3% @ 220VAC
Continuous power350W
Rated power700W
Peak power900W
EfficiencyMax. 98%
Dimensions96 x 96 x 38mm
Weight310g
InputScrew terminals
OutputPCB Connector
OutputScrew terminals
Output voltage (V)60.0
Output voltage (V)12.0
Output current (A)6.5
Output current (A)0.5
Input voltage (V)230.0
Input voltage (V)240.0
Input voltage (V)220.0
Power SupplySMPS
2 reviews
Auxiliaire, pas terrible
Autant la sortie principale est bonne, stable, on peut taper dedans. Autant la sortie auxiliaire, bof.
Ne permet même pas d'alimenter un module softstart. (2 relais 12v). Pas de protection, une diode a cramé.
This review has been posted for Switching Power Supply Module 700W +/-60V
SMPS
Excellent rapport Q/P, tensions vérifiées : très propres . Encombrement réduit . parfait pour modules UCD 400.
J'aurais préféré des sorties principales sur faston plutôt que sur borniers à vis, à voir sur la durée.
This LLC switch mode power supply module has a main output delivering ±60V. The resonant circuitry uses a high frequency sine wave,...
