Adapter SOP8 to DIP8 Clip-On with DIP8 Soldering Socket
As its name suggests, this SOP8 to DIP8 adapter enables SOP8 OPAs to be used with DIP8 brackets. The SOP8 CMS OPAs are simply inserted into the upper part of this adapter, thanks to a cap that holds them in place.
Reference : 19097
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 16-04-2025.
Adapter SOP8 to DIP8Clip-on with DIP8 soldering socket
Photo of SOP8/SOIC8 to DIP8 adapter
As its name suggests, this SOP8 to DIP8 adapter enables SOP8 OPAs to be used with DIP8 brackets. The SOP8 CMS OPAs are simply inserted into the upper part of this adapter, thanks to a cap that holds them in place. Then simply insert the adapter into a DIP8 holder. This can be used to quickly test OPAs, or simply to be able to use SOP8 OPAs in an amplifier that accepts DIP8. In the event that your amplifier PCB does not have a DIP8 socket, a soldering socket is supplied with the adapter.
Before inserting your adapter into the amplifier, check the connection direction of the OPA SOP8. A small arrow indicates pin 1 connection. Please note that this adapter is only compatible with SOP8 200mil OPAs.
OPA connection orientationOPA dimensionsMounting an OPA in the adapter
Product typeSOP8 to DIP8 adapter
OPA compatibilityOPA SOP8 200mil
Contact materialCopper alloy
Contact platingNickel
Plating of DIP8 support contactsOr
Total dimensionsApprox. 15 x 15 x 17mm
Package1x SOP8 to DIP8 adapter
1x DIP8 soldering socket
As its name suggests, this SOP8 to DIP8 adapter enables SOP8  OPA s to be used with DIP8 brackets. The SOP8 CMS  OPA s are...
