Tulip Adapter SOIC8 / SOP8 to DIP8 Clip-on Soldering on Printed Circuit
Reference : 10963
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 24-04-2025.
This adapter allows the attachment of any OP audio amplifier SOIC 8. It allows the use of modern op amps CMS (OPA1612, LM45XX) to be soldered on a printed circuit.
Thanks to its support on spring to be clipped, you can test your amps CMS SOIC 8 "on the fly".
It can thus replace an old support for amps OP DIP 8 become incompatible with OP amps SOIC8 CMS on a printed circuit./ P>
Warning: This support for OP SOIC 8 amp is to be soldered on printed circuit, it does not snapin a holderDIP8. The DIP 8 or the OP DIP 8 amplifier must be replaced by a printed circuit board.
Features Technical:
  • Support for Soic 8 test to clip.
  • Clamp contacts on gold plated spring.
  • (H) 27 x 20 (L) x (l) 19mm.
  • Weight: 10 gr.
