impressionnant très rapide on va voir la tenue des pannes avec de la brasure ROHS bonne tenue en main . il est mieux que la petite station Weller dont les pannes ne tienne pas le coup
Adjustable Soldering Iron 70W 480°C Ø6.4mm
This adjustable soldering iron offers a power of 70W allowing it to rise up to a temperature of 480°C. It can reach 350°C in just 8 seconds. The tip of the iron has a diameter of 6.4mm. It is however interchangeable with failures belonging to the 900M or CXG C8 ranges (not supplied). This simple and efficient soldering iron is ideal for designing your DIY projects: cable assembly, PCB soldering...
Product type | Adjustable soldering iron |
Power | 70W |
Temperature range | 100°C - 480°C |
Tip diameter | 6.4mm |
Impedance | < 2 Ohm |
Voltage | < 2mV |
Compatible tip | CXG C8 / 900M Series |
Color | Red / Black |
Total dimensions | 246 x 23.6mm |
Package | 1x Adjustable soldering iron 90W 1x Metal support 1x Sponge |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
yves p.
