Soldering iron 30W
Reference : 14876
10,90 €tax incl.
9,08 € tax excl.
Shipping date: 16-04-2025.
SOLDERING IRON 30W
Here is a light, compact, easy to handle and affordable soldering iron. It has a power of 30W and will be ideal for your basic DIY projects (construction / repair / improvement) involving adding or replacing one or more components.
A white diode is installed in the axis of the tip to help locate the tip in the circuit and perform precise soldering.
This soldering iron has a standard 1.25m power cable and connects directly to the 230V / 50Hz mains.
TypeSoldering Iron
Power30W
Power Supply230V / 50Hz
Cable Length1.25m
Dimensions230 x ?30mm
Weight134g
