ZD-735B Adjustable Soldering Iron Kit with Stand 60W 500°C
This soldering iron kit lets you perform basic soldering tasks. The set consists of a ZD-735 soldering iron, a ZD-11C soldering iron holder, a ZD-190 desoldering pump, ZD-156F ESD tweezers, ZD-160 soldering wire (10g) and 5 interchangeable soldering tips from N9-1 to N9-5. You'll have everything you need for operations such as soldering cable conductors to connectors.
Reference : 18436
22,90 €tax incl.
19,08 € tax excl.
ZD-735B
ZD-735B Kit Fer à Souder Réglable avec Support 60W 500°C
Product typeSoldering kit with adjustable soldering iron
Temperature range100°C - 500°C
Power25W (Max. 60W)
Soldering tipsx5
Power supply220-240V AC 50Hz
Dimensions200 x Ø23mm
Package1x Soldering iron ZD-735
1x Soldering iron holder ZD-11C
1x Desoldering pump ZD-190
1x ESD tweezers ZD-156F
1x Soldering wire ZD-160 (10g)
5x Interchangeable soldering tips (N9-1, N9-2, N9-3, N9-4 and N9-5)
Chauffe vite, résistance courte bien pratique pour du travail de précision.Je n'ai pas au moment où j'écris, assez de recul pour juger de la qualité et de la durabilité, mais parfait pour de l'occasionnel.
This review has been posted for ZD-735B Adjustable Soldering Iron Kit with Stand 60W 500°C
This soldering iron kit lets you perform basic soldering tasks. The set consists of a ZD-735 soldering iron, a ZD-11C...
