OYAIDE SS-47 Soldering Tin Silver 4.7% Copper 1.7% Flux 3.3% Ø1mm 500g
Oyaide's high fidelity solder, SS-47, provides high quality soldering. It contains pure 4N tin (99.993%) obtained by removing impurities to the maximum. In addition, 4.7% Silver and 1.7% Copper are added to improve the electrical conductivity and durability of the soldering.
By buying this product you get 26 loyalty points
Reference : 17848
269,00 €tax incl.
224,17 € tax excl.
Oyaide SS-47
Oyaide SS-47 Étain à Souder Soudure Argent 4.7% Cuivre 1.7% Flux 3.3% Ø1mm 50g
Oyaide's high fidelity soldering tin, SS-47, provides high quality soldering. It contains pure 4N tin (99.993%) obtained by removing impurities to the maximum. In addition, 4.7% silver and 1.7% copper are added to improve the electrical conductivity and durability of the soldering. Surface corrosion and residual chlorine are reduced to less than 0.12%. In addition, due to the presence of a special material, the SS-47 flux offers a fast diffusion rate of 83% ensuring ease of use.
Product typeTin solder
Composition4N Tin : 90.3%
Pure Silver: 4.7%
Pure Copper  : 1.7%
Flux : 3.3%
FluxLess than 0.12% of chlorine content
DiameterØ1mm
Melting point217°C
CertificationsLead free
RoHS
Net weight500g
Diameter (mm)1.0
MaterialSilver
MaterialCopper
MaterialTin
Oyaide's high fidelity solder, SS-47, provides high quality soldering. It contains pure 4N tin (99.993%) obtained by removing impurities to...
