AUDIOPHONICS RCA Input Selector 4 to 1 Reversible
This Audiophonics RCA source selector lets you connect different analog sources to an amplifier, preamplifier or active loudspeakers. Its function is to enable permanent connection of multiple sources (up to 4) to a single amplification device. Once the source selector has been integrated into a complex audio installation, simply use the rotary knob to select the active source.
Reference : 18049
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 24-04-2025.
AUDIOPHONICS RCA Source Selector
AUDIOPHONICS Sélecteur de source RCA 4 vers 1 / réversible
As a passive device, it can also be used in reverse, sending one source to several amplifiers, for example. The advantage of a source selector is that you can enjoy the convenience of changing sources without touching the connections of your Hi-Fi system. It also preserves the life of the system's mechanical parts (connectors, plugs, cables), as they are less subject to frequent handling.
Selection should be made with the amplifier switched off, to avoid switching noise. Input and output grounds are common.
ALPS switch and quality rotary knob
Source selection is made by a single accessible knob on the front panel. This rotary knob acts on a ALPS PCB-mounted mechanical selector to switch the signal. Digital markings corresponding to the RCA inputs facilitate source identification.
This type of completely passive assembly is appreciated for its very low sound coloration.
RCA connection
The 4 stereo RCA analog inputs allow you to connect as many sources as you like. The gold-plated connectors ensure good conductivity and a clear signal. Internal connections are made directly to PCB.
The whole unit is housed in a 100% aluminum case, protecting it from shocks, interference and noise.
Product typeInput selector
Power supplyPassive
Inputs4* RCA stereo
Outputs1* RCA stereo
Selection modeRotary knob
ChassisAluminum
Dimensions185*230*45mm
Weight1.2kg
Package1* Audiophonics RCA 4 to 1 reversible source selector
neutre mmais...
l'appareil est solide et presente bien, il n'apporte pas de coloration
mais...le bouton est lisse et il ne se manoeuvre pas facilement tant il manque de grip...
This review has been posted for AUDIOPHONICS RCA Input Selector 4 to 1 Reversible
This Audiophonics RCA source selector lets you connect different analog sources to an amplifier, preamplifier or active...
