Source Selector with Remote Control 3 RCA to 1 RCA / 1 RCA to 3 RCA
This source selector greatly facilitates the management of your audio sources and eliminates the need to disconnect and reconnect devices before changing them. It has 3 possible inputs for one output, all on stereo RCA connectors.
4.3 / 5
Reference : 13494
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 03-04-2025.
Source selector
Bidirectional 3 RCA to 1 RCA / 1 RCA to 3 RCA Source Selector with Remote Control
Sélecteur de source 3 RCA vers 1 RCA avec télécommande
This source selector greatly facilitates the management of your audio sources and eliminates the need to disconnect and reconnect devices before changing them. It has 3 possible inputs for one output, all on stereo RCA connectors. It also benefits from a bidirectional design to reverse the input/output direction to have one RCA at the input and 3 RCA at the output.
3 LEDs on the front of the unit indicate the source in operation and an IR remote control allows you to select a remote source or put the active source in mute mode. The circuit is integrated in a robust and compact aluminium housing.
Product typeBidirectional source selector
Inputs3x Stereo RCA
Sortie1x Stereo RCA
IR Remote cojtrolYes (battery not included)
Power supply5VDC 1A via Jack DC 5.5/2.1mm (sold separately)
Dimensions11 x 7 x 2.5cm
Housing materialAluminium
ColorSilver and Black
Package1x Source selector
1x IR Remote control
ColorSilver
Remote ControlYes
10 reviews
Fonctionne trés bien
Ce sélecteur trés pratique offre une transparence étonnante grace aux relais utilisés.
This review has been posted for Source Selector with Remote Control 3 RCA to 1 RCA / 1 RCA to 3 RCA
... pour un appareil qui fonctionne mal !
... car lorsque je l'ai mis en marche, le canal de sortie droit ne fonctionnait pas ! Dommage, car sinon, la qualité du produit est bien présente, sans coloration du son décelable...
Qu'à cela ne tienne, ce problème m'a permis de tester la qualité de service d'Audiophonics et, comme beaucoup d'autres, j'ai pu apprécier leur réactivité : ça n'a pas traîné du tout, dès le surlendemain du signalement de l'incident, j'ai récupéré un autre appareil... qui fonctionne très bien !
En conséquence de quoi je recommande et le sélecteur de source, et Audiophonics !
Excellent sélecteur d entrées RCA
Très bon sélecteur qui a le bon goût de fonctionner dans les deux sens. Selection d'entrée ou sélection d amplificateur de sortie.
Dommage que la sortie et l'alimentation soient en face avant pour l'intégration. Sinon avec la petite télécommande, les sélections sont très faciles.
Fonctionne très bien
Produit très simple d'utilisation. Je l'ai pris pour comparer 3 dac/preamplis. Je n'ai aucun soucis de son. , malheureusement je n'arrive pas à entendre une différence... Surement mes oreilles...
Pas réversible sauf si vous aimez le 50 Hz
Ce sélecteur est très mal blindé (pas du tout, probablement). Ne vous fiez pas à la description : si vous utilisez ce sélecteur "à l'envers" pour aiguiller une entrée vers plusieurs sorties, vous aurez du bruit sur les sorties non connectées. Suffisamment pour rendre l'appareil inutilisable (si vos sorties non connectées sont amplifiées). Vous aurez même du bruit sur la sortie connectée si vous le placez trop près d'un élément hifi avec transformateur intégré.
Bref, sélecteur de source seulement, et encore, à positionner soigneusement.
This source selector greatly facilitates the management of your audio sources and eliminates the need to disconnect and reconnect devices before...
