RaspTouch I-Sabre ES9018 - Streamer touch + Max2Play Silver
By buying this product you get 42 loyalty points
Reference : 11259
429,00 €tax incl.
357,50 € tax excl.
AUDIOPHONICS RaspTouch ES9018K2M
Max2play touchscreen network player with Raspberry Pi and DAC I-Sabre ES9018K2M
RaspTouch
The 7 "touchscreen of this audio player is easy to use and gives you complete control over your music library. The pre-installed and operational Max2Play software solution offers a wide range of features and uses.
Its CNC chassis is 100% aluminum and machined via a numerical control machine, allowing it to have a modern and contemporary design.
Rasptouch-Silver-Ecran-Chassis-Shadow-miRasptouch-Silver-Ecran-Chassis-Shadow-Ares9018-miniature.jpg1y9wbcwzbe.jpg
RaspTouch Max2Play - Reader ready
The RaspTouch was developed in order to offer all HiFi enthusiasts a simple, elegant, affordable, and especially High Resolution compatible solution to play your favorite music.
Usereading the Raspberry Pi and Max2Play, we offer you the possibility to get a ready-to-use high-definition network player: developed by Audiophiles for audiophiles. This community is constantly evolving and continues to bring improvements and new features, allowing it to be one of the best "OpenSource" solutions.
We allons bring to your music library a higher level of requirement with the RaspTouch.
Rasptouch
This RaspTouch project was first launched on KickStarter, and we can proudly tell you that the campaign was a great success, thanks to everyone! That's why we now offer all the models on our site, so that the greatest world can benefit.
A high fidelity and design audio player
Based on a latest generation DAC (ES9018K2M), capable of converting sampling rates up to 32bit / 384kHz, we can say that we are in the company of a high-end audio / video player that will perfectly match your inside.
Specifications DAC I-Sabre ES9018K2M
  • Digital volume control software
  • Patented Jitter® Disposal Technology
  • Dynamic range 127dB / 64bit battery and 32bit processor
  • Power Management Prevents SD Card Errors
  • High Precision Clock (Ultra Low Jitter)
  • Hyper-Stream® technology
  • 64bit battery and 32bit processor
  • Output Level 2Vrms
Rasptouch
Rasptouch
Raspberry Pi 3Model B
DACAudiophonics I-Sabre ES9018K2M 32bit / 384kHz / 127dB
screenofficial touch Raspberry 7 "
<inputs/ Td>1x RJ45 / 4x USB-A / 1x Micro SD Port
Exits1x RCA Stereo / 1x HDMI
Operating systemMax2Play pre-installed
FoodJack DC 5.5 / 2.1mm / Supplied with power supply 7V / 3A
Housing material100% Aluminum
ColorBlack and Silver
Dimensions200 x 95x 230mm
Rear dimensions175 x 55mm
Weight0.9kg
