DAYTON AUDIO 3.5K-LPF-4 Speaker Low Pass Filter 3500Hz 12dB/Octave 4 Ohm
DAYTON AUDIO 3.5K-LPF-8 Speaker Low Pass Filter 3500Hz 12dB/Octave
Dayton Audio filters make it easy to limit the frequency response of a speaker to a desired frequency band. By using a combination of different Dayton Audio filters you can create complete 2 or 3-way crossovers.
Reference : 14178
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 26-07-2024.
Dayton Audio 3.5K-LPF-4
Dayton Audio 3.5K-LPF-4 Filtre Passe-Bas pour Haut-Parleurs 3500Hz 12dB/Octave 4 Ohm
This 12dB/Octave 3500Hz low-pass filter can be combined with a Dayton Audio 3500Hz high-pass filter to create a Linkwitz-Riley crossover. It is also possible to shift or overlap filter frequencies to compensate for peaks and valleys in the frequency response of each speaker.
Product typeLow pass filter
Frequency3500Hz
Impedance4Ω
Power handling250W
Capacitor value5.7µF
Inductor value0.36mH
Dimensions100 x 60mm
Impedance (Ω)4
Dayton Audio filters make it easy to limit the frequency response of a speaker to a desired frequency band. By using a combination of different...
