Wall Fixation for speakers Heavy Duty Shadow Mount by DAYTON AUDIO
A wall mount to install your speakers cleanly, save space and enjoy a wider and vibrant sound. Rotating turntable for optimal management of directionality. Load up to 25 kg.
Reference : 12635
39,90 €tax incl.
33,25 € tax excl.
Wall Mount Shadow Mount series by Dayton Audio
Shadow Mount DAYTON AUDIO wall mounts
The SWMHD series (Shadow Mount) by Dayton Audio is a safe option for a secure fixation of your library speaker on a wall The fastening clamps can be adjusted with ease on a range from 13.5 to 28 cm. These fasteners will be able to work safely with most speakers types available on the market. Robustness is undoubtedly one of the highlights of these wall mount since each can support up to 25 kilograms of sound.
These bindings are equipped with rotating platforms. It is possible to adjust and direct the speaker at one's convenience to match the directionality of the speakers with the specificity of the room.
Optional Cable System concealment
A cable management system of well thought
The cable management enthusiasts will appreciate the cable laypout function that will ensure a clean result by preventing a cable jungle. According to the possibilities of your installation, Shadow Mount Series supports wall pass or a along-the-wall clean fixation for a discreet and easy installation.
Installation requires the basic hardware and no bad surprises: a drill of 3.8 mm, a drill bricklaying 8mm, a screwdriver and a spirit level. These bindings are compatible with wood and brick surfaces
These bindings are compatible with M4 security screws. It is therefore possible to ensure an optimal fixation for your speakers.
max25 kg
Weight2.56 kg
vertical rotationYes
horizontal rotationYes
Amplitude of the horizontal axis7.5 ° Up / Down
Amplitude of the vertical axis45 ° Left / Right
MaterialMetal
DAYTON AUDIO SWMHD Wall-mount for speakers 2 pieces
A wall mount to install your speakers cleanly, save space and enjoy a wider and vibrant sound. Rotating turntable for optimal management of...
