By buying this product you get 40 loyalty points
The Dynaudio Stand 10 speaker stands have been designed to allow you to position your bookshelf speakers in an optimal way. With a height of about 60cm, they bring the speakers to ear level, in a sitting position, so you can enjoy all the nuances of your sound system. The top shelf of the Stand 10 measures 15x18cm and can accommodate the EMIT 10 bookshelf speaker model. Moreover, it integrates non-stick rubber pads, ensuring a perfect stability to your speakers.
Each Stand 10 comes with four height-adjustable decoupling spikes. They allow you to adjust the level of the stand according to the slope of your floor, while absorbing the vibrations generated during listening. Sturdy and lightweight, the Stand 10 stands are made of aluminum and have a ballast compartment.
Also, a speaker cable passage allows to hide them in the stand for a discreet installation. Finally, the stand is tiltable by 10°.
Product type | Speaker stands |
Material | Aluminium |
Height without spikes | 593mm |
Height with spikes | 617mm |
Base width | 273*296mm |
Top plate width | 150*180mm |
Spikes | Adjustable |
Weight compartment | |
Cable passage system |
Dimensions | 296*593*273mm |
Weight | 3.2kg |
Color | Black |
