ISOACOUSTICS APERTA SUB Subwoofer Stands 265x290x33 mm 36.3kg Black (Unit)
The Sub Aperta prevents the physical transfer of energy to the subwoofers support surface as well as the return of vibrations to the subwoofer thanks to its patented IsoAcoustics soundproofing. This innovative product sets a new standard in soundproofing with its sleek design and aluminum frame. This technology will allow you to avoid disturbing your neighbors while keeping bass with greater clarity and definition.
Reference : 17429
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 23-04-2025.
IsoAcoustics Aperta SUB
Subwoofer stand 265x290x33 mm 36.3kg Black (Unit)
ISOACOUSTICS APERTA SUB Support de caisson de basses / Subwoofer 265x290x33 mm 36.3kg Noir (Unité)
Innovative low profile shape
The innovative shape of the Aperta Sub allows it to be positioned directly under the subwoofer enclosure without interference with existing stands. Its dimensions 265 x 290 x 33mm provide acoustic soundproofing with a discreet design. It is designed for use with front and side firing subwoofers weighing up to 80lbs (36.3kg). As a bonus, the mat discs are included and provide a solid connection to the mat and a solid base for your subwoofers.
Better bass with noise reduction
The insulators are directional and are designed to be positioned with the logo facing forward. This allows you to overcome the lateral deviation and oscillations which will bring more precision to your bass. This results in clearer low frequencies, cleaned of their muddy sound, which will allow you to enjoy your music or your movies without disturbing the neighborhood.
SpEcifications
Product TypeSubwoofer stand
Dimensions (L*P*H)265*290*33mm
Max load36.3kg (80lb)
GEnEral
ConditionnnigSold with 1x Aperta Sub et 4x mat discs
The  Sub Aperta  prevents the physical transfer of energy to the subwoofers support surface as well as the return of vibrations...
