ISOACOUSTICS ISO-155 Speaker Stands 18kg 155x190x76mm Black (Pair)
The ISO-155 model allows you to improve the placement of your monitors or loudspeakers thanks to 14 variations of position (height and inclination) available. Featuring the patented IsoAcoustics isolation system, these speaker stands offer high-quality isolation and decoupling for better sound reproduction. ISO-155 stands help your speakers deliver clearer, more natural sound. One stand can support up to 18kg depending on its setting.
Reference : 17817
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 24-04-2025.
Speaker Stands 155x190x76mm 18kg Black (Pair)
ISOACOUSTICS ISO-155 Support d'Enceintes 155x190x76mm 18kg Noir (La paire)
The ISO stand system is the latest series of innovative loudspeaker stands developed by IsoAcoustics. The ISO stand series can be described as the new, updated version of the ISO-LR08 series. Specially designed for studio monitors, the new ISO range features a lower profile with numerous improvements.
ISO-155: Optimize your speaker placement
The ability to adjust both the height and the angle of inclination of your monitors allows you to place them in the optimum position in relation to your usual listening location. The adjustment of the tilt angle is 6.5° either upwards or downwards. ISO-55s eliminate the reflection of sound waves on the support surface.
Pure and clear sound
To preserve natural, spatial sound, ISO-155s reduce internal sound reflections, eliminating the risk of smears. This keeps your sound clean and pure. These isolators also reduce vibrations caused by the monitors on the stand, eliminating any dissonant sounds that may appear in your listening area.
Prodcut typeSpeaker stands
Dimensions (W*D*H)155*190*210 mm
Tilt angleUp to 6.5°
Weight capacity in short setting18kg
Weight capacity in tall setting16kg
PackageSold by pair
Ça marche!
J’ai pu mettre quasiment à niveau mes enceintes posées sur deux support inégaux en hauteur. Et cela découple bien du support avec un son amélioré. L’assemblage est astucieux et le réglage de l’inclinaison parfait. Prix correcte.
This review has been posted for ISOACOUSTICS ISO-155 Speaker Stands 18kg 155x190x76mm Black (Pair)
The ISO-155 model allows you to improve the placement of your monitors or loudspeakers thanks to 14 variations of position (height and inclination)...
