Speaker stands 71cm (Pair)
Pangea Audio's new DS400 speaker stand uses heavy-duty support pillars to provide an incredibly strong and rigid base for compact monitors and other bookshelf speakers.
The Pangea Audio DS400 speaker stand features four rectangular steel support pillars, forming an incredibly strong rectangular support structure for enhanced speaker performance. In addition, the four support pillars can be filled with sand or steel shot for improved vibration damping.
The DS400 stands feature a 15cm wide by 22cm deep steel top plate to suit a wide range of compact and monitor speakers, and an extra-sturdy 3mm thick bottom plate measuring 25cm by 32cm. The DS400 is supplied with adjustable carpet spikes.
Type of product | Speakers stands |
Maximum weight supported per stand | 55kg |
Height without spikes | 710mm |
Base width | 250 x 320mm |
Top plate width | 150 x 220mm |
Spikes | Adjustable |
Color | Black |
Net weight of each stand | 12.5kg |
Gross weight with packaging (Pair) | 30kg |
Package | 2* DS400 Stand 71cm 8* Adjustable decoupling spikes 8* Rubber feet |
