TRIANGLE S01 Speaker Stands (The pair)
The Triangle S01 speaker stands have been designed to allow you to position your bookshelf speakers in the best possible way. With a height of 60cm, they bring the speakers to ear level, in a sitting position, so you can enjoy all the nuances of your sound system.
4.7 / 5
Reference : 15995
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 22-04-2025.
Triangle S01
Speaker stands (Pair)
Triangle S01 Pieds d'enceintes (La paire)
The Triangle S01 speaker stands have been designed to allow you to position your bookshelf speakers in the best possible way. With a height of 60cm, they bring the speakers to ear level, in a sitting position, so you can enjoy all the nuances of your sound system. The top shelf of the S01 measures 16.5 x 21.5cm and can accommodate many bookshelf speaker models. In addition, it incorporates a non-slip, anti-scratch felt, ensuring stability and protection for your speakers.
Each S01 stand comes with four height-adjustable decoupling spikes. They allow you to adjust the level of the stand according to the slope of your floor, while absorbing the vibrations generated during listening. Sturdy, the S01 stands are made of steel and are capable of supporting a load of up to 20kg.
Finally, the speaker cables can be hidden in the stand for a discreet installation.
Product typeSpeaker stands
Height without spikes600mm
Base width230 x 270mm
Top plate width165 x 215mm
Cable passage
SpikesAdjustable
Dimensions270 x 600 x 230mm
Weight8.1kg
3 reviews
Encomenda recebida
Suporte de coluna montado, perfeito.
This review has been posted for TRIANGLE S01 Speaker Stands (The pair)
TB rapport Q/P
J'ai heureusement trouvé ici ces pieds d'enceintes à un tarif très convenable. En effet, les pieds "propriétaires" assortis spécialement (paraît-il) à mes nouvelles enceintes étaient "proposés" pour une somme six fois supérieure...
Le design est très bon, le montage aisé et la stabilité sur pointes + contre-pointes reste plus que correcte.
Ces contre-pointes reposent sur des plateaux en bois de 25mm d'épaisseur qui isolent du sol et positionnent le plateau supérieur à 66cm sur la verticale, ce qui est idéal pour mon modèle d'enceintes bibliothèque.
Un conseil : enlevez tout objet pouvant se trouver à 60cm (voire plus) autour de ces pieds ; le rendu sonore n'en sera que meilleur !
stabilité et rapportQ/P
Extrêmement satisfait de mon achat à prix plus que contenu. Bonne qualité de fabrication (contre-point es un peu cheap), Esthétique discrète et bonne stabilité
The Triangle S01 speaker stands have been designed to allow you to position your bookshelf speakers in the best possible way. With a height of...
