By buying this product you get 27 loyalty points
Triangle S05 speaker stands are designed for bookshelf models. They provide excellent stability and optimal speaker positioning. With a height of 62cm, the Triangle S05 speaker stands enable you to place your speakers at ear height for optimum diffusion of your music.
Designed to accompany HiFi speakers, the S05s benefit from a robust design optimized to absorb speaker vibrations. The 18 x 29.5cm top plate is capable of supporting the vast majority of bookshelf speakers weighing up to 25kg. An anti-slip coating ensures that speakers stay in place.
The aluminum center tube ensures perfect structural rigidity and helps absorb vibrations. A grommet system at the rear of the tube allows discreet integration of your speakers into your audio system. The stand can also be weighted with fine sand or steel balls (not supplied) to enhance sound performance.
Elegant and modern, Triangle S05s boast a magnificent design. The bottom shelf is finished in high-temperature molded glass. It is also fitted with height-adjustable steel decoupling spikes. Rubber feet are also available, depending on the floor covering.
Product type | Speaker stands |
Height without spikes | 620mm |
Height with spikes | 640mm |
Base dimensions (W x D) | 260 x 320mm |
Top plate dimensions (W x D) | 180 x 295mm |
Grommet | Yes |
Decoupling spikes | Yes Height-adjustable steel spikes or rubber studs |
Ballast foot | Yes Steel beads sold separately |
Total dimensions (L x H x P) | 260 x 620 x 320mm |
Weight | 9kg / stand |
Color | Black |
