Triangle's Stand Filler ballast increases the weight of speaker stands by integrating them into the tube or base. Made from high-density metal micro-cylinders, these balls add weight to the stands, further reducing the vibrations generated by the loudspeakers, while minimizing the risk of resonance. Triangle Stand Filler ballasts can be used in particular with S04, S04 40TH, S05, S08 and S08 C stands.
Product type | Ballast for speaker stands |
Material | Steel |
Quantity | 4 x 1kg sachets (total = 4kg) |
