ATOHM WT-7992-G Isolated Built-in Terminal Block for Speakers Gold plated 92x79mm (Unit)
The WT-7992-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold plating. It accepts cables with large cross-sections, up to 6mm².
Reference : 17278
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 22-04-2025.
Atohm WT-7992-G
Speaker Terminal Block Gold Plated 92x79mm
Atohm WT-7992-G
The WT-7992-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold plating. It accepts cables with large cross-sections, up to 6mm², and its cup is made of reinforced ABS plastic. A seal at the back allows a reliable mounting on your speakers.
Product Terminal Block for Speakers
Contacts materialLead-free Brass
Contacts platingGold 24k
Body materialReinforced ABS plastic
Banana plugs support
Total dimensions92x79mm
Package1x Speaker Terminal
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Très bien
La marque ATHOM n'apparaît pas mais inspire le sérieux aussi bien pour le plastique épais et pas cassant et le bornier proprement dit en métal massif bien plaqué.
This review has been posted for ATOHM WT-7992-G Isolated Built-in Terminal Block for Speakers Gold plated 92x79mm (Unit)
The WT-7992-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold...
