ATOHM WT-D105-G Isolated Built-in Terminal Block for Speakers Gold plated Ø105mm (Unit)
The WT-D105-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold plating. It accepts cables with large cross-sections, up to 6mm².
Reference : 17280
5,90 €tax incl.
4,92 € tax excl.
Atohm WT-D105-G
Speaker Terminal Block Gold Plated Ø105mm
ATOHM WT-D105-G
The WT-D105-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold plating. It accepts cables with large cross-sections, up to 6mm², and its cup is made of reinforced ABS plastic. A seal at the back allows a reliable mounting on your speakers.
Product Terminal Block for Speakers
Contacts materialLead-free Brass
Contacts platingGold 24k
Body materialReinforced ABS plastic
Banana plugs support
Total diameterØ105mm
Package1x Speaker Terminal
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
The  WT-D105-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold...
