CC E-SERIES Wall Plate Wiring Kit with 2 Binding Post Aluminium Silver
These E-Series CC plates will also allow you to mount HP terminal blocks on a wall or in a speaker box. Predrilled and delivered with two HP terminals accepting banana plugs, this kit will allow you an easy assembly.
Reference : 12782
6,90 €tax incl.
5,75 € tax excl.
CC E-Series
Wall plated with binding post Aluminium Silver
Copper Color Plaque Murale avec borniers HP
These E-Series CC plates will also allow you to mount HP terminal blocks on a wall or in a speaker box. Predrilled and delivered with two HP terminals accepting banana plugs, this kit will allow you an easy assembly. Made of 3.8mm thick sandblasted aluminium, the plate will prove resistant and durable.
For use on a speaker box we strongly recommend adding a gasket so as not to damage the return of your equipment.
Plate
MaterialSandblasted Aluminium alloy
ColorSilver
Dimensions86 x 86 x 3.8mm
Binding post holes spacing20mm
Screws holes spacing62mm
Binding post holes diameter6.5mm
Binding post
Conductor materialBrass
Quantity2 (1 Black / 1 Red)
Accepts banana plugssYes
Total Dimensions36 x 14.8mm
Drilling diameter6.3mm
Max panel thickness9mm
Package content1x Aluminium plate
2x binding post(1 Black, 1 Red)
2x screws
Mounting typeTo weld
Accepts Banana PlugsYes
These E-Series CC plates will also allow you to mount HP terminal blocks on a wall or in a speaker box. Predrilled and delivered with two HP...
