DAYTON AUDIO Double Insulated Speaker Terminals with Holding Plate 5mm
These speaker terminals with retaining plate are easy to install on your speakers or enclosures.
Reference : 16731
5,50 €tax incl.
4,58 € tax excl.
Shipping date: 22-04-2025.
Speaker terminals
Borniers double isolés avec plaque de maintien 5mm
These HP terminals with retaining plate can be easily installed on your speakers or boxes. The retaining plate allows efficient fixing of the terminals while isolating the contacts from the panel on which the terminals are placed. In addition, the terminals accept banana plugs for easy connection.
Product typeSpeaker terminals
Max panel thickness5mm
Spacing between terminals19mm
Support banana plugsYes, up to 4mm
Max cable diameter2mm
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)5.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
