Double Insulated Gold Plated Speaker Terminals with Holding Plate 5mm
These HP terminals with retaining plate can be easily installed on your speakers or boxes. The retaining plate allows efficient fixing of the terminals while isolating the contacts from the panel on which the terminals are placed. In addition, the terminals accept banana plugs for easy connection. The contacts are gold plated to ensure very good signal conductivity and excellent oxidation resistance.
Product type | Speaker terminals |
Max panel thickness | 5mm |
Contacts plating | Gold |
Spacing between terminals | 19mm |
Support banana plugs | Yes, up to 4mm |
Max cable diameter | 4mm |
