Isolated Built-in Terminal Block for Speakers 75x55mm
These speaker terminal blocks have screw-in connectors, which also accept banana plugs (4mm). The drilling diameter is 75x55mm.
4.5 / 5
Reference : 12460
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 24-04-2025.
Speaker terminals
75x55mm
Borniers pour enceintes
These speaker terminals include screw connectors that also accept banana plugs. The terminal block contacts are made of gold-plated copper to ensure both good conductivity and oxidation resistance. At the back of the plate is a foam gasket to seal the enclosure housing.
Contacts materialCopper
PlatingGold
Drilling diameter75x55mm
Space between fixing holes77mm / 66mm
Connecting speaker cablesTo be screwed or banana plugs
Acceptable diameter banana plugs4mm
Dimensions92 x 80 x 36mm
Panel materialABS Plastic
Screws not supplied-
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
2 reviews
Bien le Encastré
3 commandés avec d'autres articles. Traitement et livraison 2 jours, c'est top. En revanche cet article n'est pas emballé et il s'est rayé pendant le transport.
This review has been posted for Isolated Built-in Terminal Block for Speakers 75x55mm
Bornier Encastré
bon produit fourni avec joint mousse
