JANTZEN AUDIO 012-0060 Aluminum end plate with terminal gold plated blocks
4.3 / 5
Reference : 6095
26,90 €tax incl.
22,42 € tax excl.
This terminal connection kit for your DIY loudspeakers includes an aluminum plate, mounting screws and two (screw-on) terminal blocks.
Features:
  • Dimensions: 100 x 100 mm
  • Space between the 2 holes of the terminal blocks: 30mm
  • Compatible with all terminal blocks with diameters 11.5mm
  • Supplied with screws (4 screws) and two terminal blocks JANTZEN AUDIO BP1G
Terminal Blocks:
  • External Diameter 14mm (16mm Wheel)
  • Panel Drilling Diameter: 9mm and 11.5mm
  • Maximum Panel Thickness: 26mm
  • Diameter of the hole or inserts the wires: 5mm
  • Compatible with audio banana plugs (4mm)
  • Height out of the case: 70mm
https://www.audiophonics.fr/images2/6090/6090_JANTZENM926G_1.jpg
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
3 reviews
parfait
les borniers ne tournent pas quand on serre, la soudure est facile
This review has been posted for JANTZEN AUDIO 012-0060 Aluminum end plate with terminal gold plated blocks
bornier
tres bon produit, respire la qualité bon rapport qualité pris.
La peinture de finition est moyenne, je ne m'attendais pas à ça. Je pense que je vais repeindre la plaque.
 (3)
