JANTZEN AUDIO Carbon Speaker Terminal Blocks with Aluminum Mounting Plate 100x100mm
These carbon-finish speaker terminals come with a 100 x 100mm brushed aluminum mounting plate. This makes it easy to mount to a speaker cabinet with only 4 screws. The watertightness is ensured by a gasket on the back of the plate.
Reference : 15167
49,90 €tax incl.
41,58 € tax excl.
Jantzen Audio Speaker Terminals
Jantzen Audio borniers enceintes carbone avec plaque de montage Aluminium
Product typeSpeaker terminals with mouting plate
Speaker terminals finishCarbon
Speaker terminals screw threadM8
Mounting plate materialBrushed anodized aluminum
Mounting plate dimensions100 x 100mm
Mounting plate colorBlack
Package2x Speaker terminals
1x Mounting palte
4x Screws
1x Gasket
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
These carbon-finish speaker terminals come with a 100 x 100mm brushed aluminum mounting plate. This makes it easy to mount to a speaker cabinet...
