KIWI EARS CADENZA In-Ear Monitors Blue
New
Kiwi Ears Cadenza are in-ear headphones featuring a large 10mm diameter dynamic driver with beryllium cone. This type of membrane is often considered to be the most powerful.
Reference : 20631
34,90 €tax incl.
29,08 € tax excl.
Kiwi Ears Cadenza In-Ear Monitors IEM Dynamic 32 Ohm 110dB 20Hz-20kHz Blue
Photo of Kiwi Ears Cadenza
Kiwi Ears Cadenza are in-ear monitors featuring a large 10mm diameter dynamic driver with beryllium cone. This type of membrane is often considered to be the most powerful.
Photo of Kiwi Ears Cadenza in-ear monitors
Kiwi Ears Cadenza: 10mm dynamic driver
Kiwi Ears Cadenza IEMs feature a dynamic driver with a 10mm-diameter beryllium cone. This technology offers great clarity and resolution across the entire frequency range. The unique properties of beryllium - thinness, lightness and rigidity - enable the diaphragm to respond quickly to audio signals, ensuring that every detail of the sound is reproduced with great fidelity.
Kiwi Ears Cadenza: Optimized shells
The shell of Kiwi Ears Cadenza earphones is carefully designed to optimize speaker performance. The shell is 3D printed to precise specifications, ensuring perfect speaker alignment and fit. This precision engineering contributes to the Cadenza's balanced sound signature, allowing the bass to retain the power and speed of response characteristic of beryllium, while avoiding a bulge in the midrange. The result is a rich, natural sound.
Kiwi Ears Cadenza: A natural sound
L'une des caractéristiques principales des IEM Kiwi Ears Cadenza est leur capacité à délivrer un son à la fois naturel, précis et sans fatigue auditive. La réponse des aigus des Cadenza a été soigneusement réglée pour refléter la norme de référence Harman, avec une courbe naturelle et une réponse sans agressivité. Malgré ce son naturel, les aigus dévoilent de nombreux micro-détails pour retranscrire toutes les nuances de la musique.
Kiwi Ears Cadenza: Powerful bass
The Cadenzas have been acoustically tuned to deliver accurate, faithful sound. Bass is punchy and fast, and attenuates quickly enough not to dominate other frequencies. Mids are tuned to be rich but not excessive, allowing vocals and instruments to shine with exceptional clarity. Highs, meanwhile, are tuned to the Harman reference standard, for a natural, balanced sound that's detailed but not fatiguing to the ear. This meticulous tuning ensures that Kiwi Ears Cadenza deliver faithful, full sound, suitable for a wide range of musical genres.
Photo of Kiwi Ears Cadenza in-ear monitors cable
Kiwi Ears Cadenza: High-quality cable
Cadenza comes with a high-quality detachable cable, using braided copper conductors to ensure excellent conductivity. This cable terminates in a 3.5mm jack connector for maximum compatibility. It connects to the earphones using CIEM 0.78 mm 2-pin connectors, and can therefore be easily replaced.
Kiwi Ears Cadenza frequency response curve
Product typeIn-ear monitors
DriversDynamic 10mm, beryllium diaphragm
Sensitivity110dBSPL/mW
Impedance32Ω
Shell materialMedical-grade resin
Detachable cableYes
In-ear monitors connectorCIEM 0.78mm 2 pins
Cable end connectorJack 3.5mm
Channel separation88dB
SNR95dB
Supported sampling ratesCoaxial: up to 192kHz
Bluetooth (LDAC): up to 96kHz
ColorBlue
Package1x Kiwi Ears Cadenza
1x Jack 3.5mm cable
6x Eartips pair
KIWI EARS CADENZA In-Ear Monitors IEM Dynamic 32 Ohm 110dB 20Hz-20kHz Blue
Kiwi Ears Cadenza are in-ear headphones featuring a large 10mm diameter dynamic driver with beryllium cone. This type of membrane is often...
