By buying this product you get 109 loyalty points
With the Twilight, Softears presents top-of-the-range dynamic in-ear earphones whose lightweight, high comfort fit is only equalled by the quality of their sound reproduction. They have benefited from intensive research and development work to perfect a dynamic driver and associated acoustic cavity offering the most striking sound possible.
The Twilight's body is made from an aeronautical-grade aluminium alloy that is both strong and light. The latter is the result of high-precision 5-axis CNC machining and undergoes an anodic oxidation post-treatment. What emerges are classy earphones that weigh in at an incredibly low 6g, making them a pleasure to wear.
The Twilight is based on a dynamic driver specially designed by Softears for this project. This uses a 10mm diameter DLC (Diamon-Like Carbon) cone coupled to a polyurethane free edge suspension. Once paired with the 0.035mm Daikoku voice coil, the result is a rich sound reproduction with a wide frequency response.
Considerable research and development work went into the Twilight acoustic cavity. This cavity, tailor-made to match the driver used, improves the dynamic range of the earphones while favouring low frequencies. Furthermore, viscoelastic damping materials and diffusion plates are integrated into the cavity, eliminating undesirable resonances for finer resolution of sound reproduction.
The Twilight comes with accessories to match its quality. The cable supplied is made from OFC 6N copper for optimum conductivity, and has gold-plated CIEM and 3.5 mm jack connectors to guarantee unfailing protection against oxidation and corrosion.
The Softears Twilight is an impressive interpretation of a single dynamic driver IEM tuning that up until this point I felt had been done to death.
Product type | In-Ear Monitors |
Driver | Dynamic driver Ø10mm |
Frequency response | 15Hz-40kHz (-3dB) |
Impedance | 16Ω |
Sensitivity | 116dB |
Total harmonic distortion (THD) | <1% @1kHz |
Earphone connectors | CIEM 0.78mm 2 pins |
Cable conductor material | Cuivre OFC |
Cable termination | Jack 3.5mm |
Color | Black |
Package | 1x Softears Twilight 1x CIEM to 3.5mm jack cable 1x Carrying bag 1x 3.5mm to 4.4mm jack adapter 9x Pairs of ear tips |
Color | Black |
Impedance (Ω) | 16 |
Efficiency / Sensitivity (dB) | 116.0 |
Wireless | No |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
