ATOHM SIROCCO 2-0 HiFi tower Speaker 250W / 6 Ohm White (Unit)
By buying this product you get 81 loyalty points
Reference : 11236
819,00 €tax incl.
682,50 € tax excl.
Fine and elegant, the SIROCCO 2.0 offers ample and detailed sound reproduction at the same time. The bass is built to perfection. The acute midrange is particularly well defined, but without distorting or aggressive listening. The sound reproduction is of a homogeneity and an exemplary depth This column loudspeaker is particularly designed for small and medium sized pieces.
You will findns the documents attached below 3 PDF files on the SIROCCO range of ATOHM.
Features:/ Strong>
  • Speakers: 2 + 1 way - Bass Reflex
  • Power Rating: 140Weff
  • Power Rating: 250W
  • Impedance: 6 Ohm
  • Sensitivity level: 89dB / 2.83V / 1m
  • Frequency response: 42Hz - 25kHz
  • Switching Frequency: 3kHz
  • Boomer low medium: LD130CR08 x2
  • Tweeter: SD20ND04F
  • Slope of filtering: 1st electrical order with timing of the tweeter
  • Case: MDF 19mm
Packaging:
  • Finish: Satin White
  • Dimensions: 1044x180x200mm
  • Weight: 18kg
  • Sold individually
ColorWhite
