DAYTON AUDIO MK402X Bookshelf Speakers 2 Way 40W 4 Ohm 84dB 60Hz-20kHz (Pair)
The Dayton Audio MK402X 2-way bookshelf loudspeakers offer excellent sound reproduction, thanks in particular to the integration of a crossover filter that delivers high frequencies with softness and flexibility.
Reference : 14534
109,00 €tax incl.
90,83 € tax excl.
Dayton Audio MK402X
Dayton Audio MK402X Enceintes Bibliothèques 2 Voies 40W 4 Ohm 84dB 60Hz-20kHz
Each loudspeaker is composed of a dome tweeter and a woofer to reproduce a wide range of frequencies. All the components are integrated in a textured black box with a geometric design of the most beautiful effect.
Silk dome Tweeter Ø1.9cm
The Ø1.9cm (0.75") diameter silk dome tweeter on the MK402X provides soft, airy highs for a delicate, non-aggressive sound. Since sound waves are widely dispersed by this tweeter, it promotes a wide and realistic sound stage.
Woofer Ø10.2cm
The Ø10.2cm (4") diameter woofer built into each MK402X is capable of delivering low frequencies up to 60Hz. The frequency response of this woofer is also uncut, allowing it to unveil beautiful low-midrange/midrange, for a deep and coherent reproduction.
Crossover
The integrated crossover filter provides soft sound reproduction for listening sessions without auditory fatigue. Incorporating 7 components, the crossover uses asymmetrical slopes to combine the two speakers in a very musical way. It also flattens the high-frequency response curve for smoother sound.
Dayton Audio MK402X review by Audioholics (EN)
Test Dayton Audio MK402X par AudioHolics
Dayton MK402X review by Audio Science Review (Amir)
" Somehow the designer managed to deal with the compromises just right to create a speaker that produces a very good experience with equalization. Overall, I am going to recommend the Dayton MK402X. If you need a pair of speakers that can excite you with well recorded music most of the time and not cost more than a dinner, you have found it. "
Test des Dayton MK402X par Audio Science Review (Amir)
Product typeBookshelf speakers
Number of ways2
Bass-Reflex
Speaker drivers1x Treated-paper woofer Ø10.2cm (4") with 4 layer voice coil
1x Silk dome tweeter Ø1.9cm (0.75") with ferrofluid cooling
Input impedance4 Ohm
Power handlingRMS : 40W
Max : 80W
Frequency response60Hz - 20000Hz
Sensitivity84dB 1W/1m
Crossover3.3kHz
Third order high-pass
Second order low-pass (asymmetrical slopes)
ConnectorsSpeaker terminals (compatible with banana plugs)
Port tuning50Hz
Dimensions5-3/4" x 9-1/2" x 6-5/8"
14.6 x 24.1 x 16.8cm
Weight10.3lbs.
4.7kg
QuantitySold by pair
Impedance (Ω)4
Efficiency / Sensitivity (dB)84.0
Lowest frequency (Hz)60
Highest frequency (Hz)20000
Power (W)40.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
The Dayton Audio MK402X 2-way bookshelf loudspeakers offer excellent sound reproduction, thanks in particular to the integration of a crossover...
