DAYTON AUDIO MK442 Center Channel Speaker 2 Way 80W 4 Ohm 86dB 60Hz-20kHz
The Dayton Audio MK442 2-way centre speaker (two woofers and a tweeter) offers excellent sound reproduction at a more than reasonable price.
Reference : 14533
89,00 €tax incl.
74,17 € tax excl.
Dayton Audio MK442
Dayton Audio MK442 Enceinte Centrale 2 Voies 80W 4 Ohm 86dB 60Hz-20kHz
Silk dome tweeter Ø1.9cm
The Ø1.9cm (0.75") diameter silk dome tweeter, located in the centre of the MK442 loudspeaker, provides soft, airy highs for a delicate, non-aggressive sound.
Dual woofers Ø10.2cm
On either side of the speaker, Ø10.2cm (4") diameter woofers are used to reproduce low frequencies up to 60Hz. The frequency response of these woofers is not cut off, allowing them also to unveil beautiful low-midrange/midrange, for a deep and coherent reproduction.
Dayton Audio MK442 review by Audioholics (EN)
Test Dayton Audio MK442 par AudioHolics
Product typeCenter channel speaker
Number of ways2
Speaker drivers2x Treated-Paper Woofer Ø10.2cm (4") with 4 layers voice coil
1x Silk dome Tweeter Ø1.9cm (0.75") with ferrofluid cooling
Input impedance4 Ohm
Power handlingRMS : 80W
Max : 160W
Frequency response60Hz - 20000Hz
Sensitivity86dB 1W/1m
CrossoverThird order high-pass
Second order low-pass
TerminalsSpeaker terminals (compatible with banana plugs)
Port tuning57Hz
Dimensions14.94" x 5.75" x 6.6"
37.9 x 14.6 x 16.8cm
Weight8.7lbs.
3.9kg
Impedance (Ω)4
Efficiency / Sensitivity (dB)86.0
Lowest frequency (Hz)60
Highest frequency (Hz)20000
Power (W)60.0
Number of ways2
Number of loudspeakers3
Speaker typePassive
Speaker form factorCenter speaker
