Q ACOUSTICS 3070S Active Subwoofer 140W
This active Q Acoustics 3070S subwoofer, capable of delivering 140W thanks to its two 170mm loudspeakers, is the ideal companion for Q Acoustics 3010,3020 or 3050 speakers!
By buying this product you get 39 loyalty points
Reference : 12428
399,00 €tax incl.
332,50 € tax excl.
Including 1,00 € for green tax
Q Acoustics 3070S
Great calm to power!
The Subwoofer Q Acoustics 3070S is capable of delivering 140W RMS thanks to its two 170mm bass-medium speakers. This box, capable of moving from absolute silence to explosive power in an instant, will brilliantly accompany your favourite music or movies.
q acoustics 3070s
Strong and precise
Like its predecessor known for its performance - the 2000 Series 2070Si - the 3070S uses a two-speaker system rather than a single speaker system to achieve superb sound depth. In addition, the Q Acoustics subwoofer incorporates a 140W amplifier perfectly adapted and calibrated to provide the 3070S with the power it needs.
q acoustics 3070s
Transparent integration
With its 200mm width, the 3070S is capable of fitting into tight spaces, where the usual subwoofers would find it difficult to fit. The 3070S is actually even more compact than its predecessor, the 2070Si, while significantly improving its performance and design.
q acoustics 3070s
The 3070S is supplied with tips with rubber plates to ensure excellent stability and fit most surfaces.
Speaker typeSubwoofer
Subwoofer typeActive
Load typeBass Reflex
Subwoofer power140W RMS
Loudspeakers type2x Grave-Medium 170mm
Crossover frequency50 - 150Hz
ColorGraphite black
Max dimensions (with grille and spikes)200 x 425 x 535mm
Min dimensions (without grille spikes)200 x 400 x 525mm
Weight13.6kg
Package1x 3070S Subwoofer
1x Magnetic Speaker Grille
1x User Manual
1x AC Power Cable
4x Adjustable Floor Spikes
This active Q Acoustics 3070S subwoofer, capable of delivering 140W thanks to its two 170mm loudspeakers, is the ideal companion for Q Acoustics...
