Rythmik Audio F12 Signature A370XLR2 Audiophile Subwoofer 31cm
Rythmik Audio F12 Signature A370XLR2 Subwoofer Audiophile 31cm
By buying this product you get 154 loyalty points
Reference : 8914
1 549,00 €tax incl.
1 290,83 € tax excl.
Rythmik Audio F12 Signature A370XLR2 "Audiophile" Subwoofer 31 cm
Genuine Closed Subwoofer "Audiophile" featuring the revolutionary Direct Servo technology to channel the sounding resonant effects.
Equipped with an impeccable finish and with a common technology and power, it is the indispensable complement to any system worthy of the name.
Focus on Direct-Servo technology:
  • The effects of thermal compression are eliminated during normal operation.
  • Enables greater efficiency that would normally require a more powerful amplifier.
  • The extension of the infra-low can be achieved by using a low-mass pilot with an unparalleled transient response.
  • Mechanical and thermal memory effects are reduced, which improves the transient response.
  • The effective value Q of 0.3 allows a much tighter and more precise control than the conventional models.
  • Maximum reduction of bass feedback in the cabinet
Features:/ P>
  • HP: 12 "(31 cm) high excursion driver with patented Direct Servo system
  • Amplifier module: A370XLR2
  • Input and output XLR
  • Materials: Bowl and cone Aluminum, rubber suspension
  • Amplifier 370W RMS Class A Servo B / Patented Controlled
  • Dimensions 15-3 / 4 "(L) x 15-3 / 4 "(H) x 17" (D) - (18-1 / 2 "D with grid)
  • Frequency response: 14 to 200 Hz (-2 dB @ 14 Hz) with LFE inputs in A370PEQ3 / XLR2 / XLR3
  • Frequency response: 14 to 100 Hz (-2 dB @ 14 Hz) with LINE IN inputs on all models
  • Cover slope of 12 or 24 dB / octave (PEQ and XLR versions)
  • Filter (Low Pass): 25 - 100 Hz
  • Filter (high pass): 20Hz 18 dB / octave
  • Phase phase response <90 degrees at 20 Hz
  • Phase adjustment from 0 to 180 degrees - continuous variation
  • (Q = 0.5), mean (Q = 0.7) and low (Q = 1.1)
  • Finishes: Piano lacquered
  • Weight: 28kg
https://www.audiophonics.fr/images2/7248/7248_RYTHMIK_AUDIO_F12SE_3.jpg
https://www.audiophonics.fr/images2/7248/7248_RYTHMIK_AUDIO_F12SE_1.jpg
https://www.audiophonics.fr/images2/7248/7248_RYTHMIK_AUDIO_F12SE_2.jpg
iophonics.fr/images2/7248/A370PEQ.pdf "target =" _ blank "> Manufacturer's Datasheet (PDF)
