HiVi SWANS M50W -2.1 Activ loudspeakers and Subwoofer
Swans M50W - 2.1 Activ loudspeakers and Subwoofer
By buying this product you get 44 loyalty points
Reference : 11208
449,00 €tax incl.
374,17 € tax excl.
Sound quality and easy operation are at the heart of the design of the HiVi M50W.
The Swan Research M50W Kit with a 16 cm subwoofer is a new generation of 2.1 High-Fidelity multimedia system.
The system is uniquely designed using purely Hifi design principles for a multimedia desktop system that meets high standards of audio reproduction.
The Hivi M50W has a classic design with a walnut finish and a piano lacquer. This 2.1 system uses 2 satellites plus an independent subwoofer.
The 2.1 Swan M50W kit features aluminum dome tweeters on the speakers to increase resolution and clarity at high frequency. the mediums of 10 cm give a right medium and textured.
Theubwoofer with a 16 cm loudspeaker, a 100W low-distortion amplification goes down very low at 38Hz creating a wraparound "soundstage" at low frequencies.
TheExternal control is machined aluminum. In the center of the control wheel, the color ring changes from red to blue indicating the different operating states.
This music system 2.1 is suitable for PC, iPod, DVD, CD, game consoles as well as high fidelity music and multimedia gamer systems.
Main Features :
  • Bandwidth of the kit 2.1: 20khz to 38hz (subwoofer 300hz to 38hz.)
  • Noise Ratio: 83dB
  • Nominal impedance of satellites: 8 Ohm
  • Built-in Subwoofer Amplification: 78Watt over 4 Ohm
  • Satellite Amplification: 18W x 2
  • Finish Walnut (walnut) "black piano" lacquered black
  • Subwoofer connection via 2 RCA to satellite speaker terminals
Weight & dimensions:
  • Subwoofer: 285x327x251mm
  • Satellite speakers: 140x140x180mm
  • 14kg
swan Hivi research Nw50
