NEUTRIK NL4FXX-W-L Female Speakon Connector Ø16mm
The Neutrik NL4FXX-W-L is a robust 4-pole Speakon connector, ideal for designing professional-quality cables. It incorporates a proven locking system to ensure reliable connections. The NL4FXX-W-s accepts cable diameters from 10 to 16mm.
Reference : 18047
5,70 €tax incl.
4,75 € tax excl.
Shipping date: 24-04-2025.
Neutrik NL4FXX-W-L
Connecteur Speakon Femelle Ø16mm
Neutrik NL4FXX-W-L Connecteur Speakon Femelle Ø16mm
Assembling Neutrik Speakon connectors
Product typeFemale Speakon connector
Number of contacts4
Min / Max cable diameterØ10mm / Ø16mm
Min / Max conductor section1.5-4mm² (17-11AWG)
Mounting typeTo screw
Contacts materialCopper alloy
Contacts platingSilver
Connector shell materialPolyamide (PA6) / TPE
Lifetime5000 cycles
StandardsEurope : IEC 61984 (37A 250VAC)
USA : UL1977 (35A 250VAC)
Canada : CSA C22.2 No.182.3 (24A 250VAC)
Contact resistance≤ 2mΩ
Dielectric strength2.8kVac
Insulation resistance> 10GΩ
Operating temperature range-33°C to +80°C
Protection classIP20
Max cable diameter (mm)16.0
ConnecticFemale
ConnectorSpeakon
The Neutrik NL4FXX-W-L is a robust 4-pole Speakon connector, ideal for designing professional-quality cables. It incorporates a proven locking...
