OYAIDE INS-SP Spike Pads (Set x4)
Oyaide's INS-SP are Ø20mm stainless steel SUS303 spike pads designed to effectively reduce the vibration of your HiFi equipment. They feature a 2mm recess on an 8.8mm diameter with a 130° concave angle, providing excellent stability even in the case of a lateral bump. To ensure resistance to friction and corrosion, the INS-SP are also chrome-plated.
Reference : 19662
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 16-04-2025.
Oyaide INS-SP Spike Pads Stainless Steel Ø20mm (Set x4)
OYAIDE INS-SP : set of 4
OYAIDE INS-SP and OYAIDE INS-BS
Oyaide INS-SP : Designed to be used with INS-US tips
Although INS-SP spike pads can be used with a wide range of spikes, they have been designed primarily to be used in conjunction with Oyaide's INS-US spikes. Once the two references are paired, you'll be able to take advantage of high-quality contact point isolation for the benefit of your equipment, with a total height of 13.9mm per foot.
Product typeSpike pads
External diameterØ20mm
Internal diameter for spikeØ8.8mm
Recess depth for spike2mm
Recessed angle for spike130°
Height6mm
MaterialStainless steel (SUS303) chrome-plated
Maximum load capacity200kg/pc
Weight14.7g/pc
Package4x Oyaide INS-SP
Diameter (mm)20.0
MaterialAcier inoxydable
Height6.0
OYAIDE INS-SP Spike Pads Stainless Steel Ø20mm (Set x4)
Oyaide's INS-SP are Ø20mm stainless steel SUS303 spike pads designed to effectively reduce the vibration of your HiFi equipment....
