JANTZEN AUDIO STANDARD Z-CAP Capacitor 400V 3.3μF
JANTZEN AUDIO STANDARD Z-CAP 3.3μF capacitor 400V
Reference : 14919
2,80 €tax incl.
2,33 € tax excl.
Shipping date: 16-07-2024.
Jantzen Audio Standard Z-Cap
Capacité MKP non-polar 3,30μF
The Jantzen Audio Standard-Z Cap series offers affordable audio capacitors for your high fidelity hardware build / repair / upgrade projects. They stand out thanks to their excellent value for money in high audio performance. These capacitors offer a high and fast reaction, detailed sound and a smooth signal compared to what the competition offers in the single polypropylene foil capacitor market.
The dielectric fluid used is nitrogen, which allows denser foil when assembling the capacitor while avoiding the risk of evaporation.
This Jantzen Audio Standard Z Cap capacitor model has a capacitance of 3,30μF for a diameter of Ø 16mm and a length of 31mm.
TypeNon-polarized MKP (single foil lane)
DielectricPolypropylene film
Construction: Round tubular type axial leads
Rated Voltage400 VDC / 250 VAC
ElectrodesAluminum metallized vacuum deposited
ContactsNon-inductive zinc thermally sprayed extended film
CoatingBlue plastic tape wrapped and sealed in black resin
LeadsTin plated oxygen free copper
Tolerance+/- 5%
Dielectric absorption factor=0.5% @20°C
Dielectric thicknessPB=5µm
Self-inductance=15 nH
Insulation resistance=100.000 MOhm@20°C
Temperature coefficient-200°Cx10-6/°C
Temperature Range-55°C à +85°C
Metal layer thicknessPB =1.2 Ohm/cm2
Capacitance3,30μF
DiameterØ 16mm
Length31mm
Capacitor capacitance3.3
Bon
Bon condo en général en remplacement de MKT de même valeur.
Comparé aux mkt ces mkp apporte plus de présence, il ne sont pas en avant mais plus présent avec plus de détail mais je sent une légère accentuation des "SSSS" et "CHHH" la gamme au dessus sera peut etre mieux pour régler ce petit souci, souci qui s'oubli facilement car il faut vraiment etre exigent. (sur une paire d'elipson mélodine 7 avec un 2.2 et un 3.3uf) restre très bon pour ce prix.
Expédition rapide et bien emballer de la par d'audiophonics.
This review has been posted for JANTZEN AUDIO STANDARD Z-CAP Capacitor 400V 3.3μF
