Livraison rapide sans problème. Ampli Sub excellent
By buying this product you get 31 loyalty points
This model is replaced by the new version: S250-X ATOHM
Module Amplificateur Class D Subwoofer
Specialized in the design and manufacture of high-end loudspeakers and loudspeaker cabinets, Atohm also designs and offers amplification modules with a very high level of performance. Thanks to their sophisticated signal processing, Atohm modules offer a wide choice of settings and connections to meet a wide range of applications such as closed-load active subwoofers or Bass-Reflex, active loudspeakers or monophonic power blocks. All this while offering excellent technical performance and musicality in a small footprint.
Important studies have been carried out by the brand on components, schematics, layout topology, power supply as well as general construction to develop the best products.
The S250 Atohm Amplifier Module includes many features and specifications :
It is possible to connect the module via the pre-out/subwoofer outputs of a preamplifier/processor or directly to the speaker outputs (in parallel) of a conventional stereo amplifier. The S250 module can also be by-passed to high performance HiFi broadband use (mono block) via a simple internal switch. In this case, only the gain control remains active. This can be used to create monitor speakers for example.
Product type | Amplifier module |
Amplification class | D |
Power | 220W RMS |
Impedance | 4-16 Ohm |
Frequency response (direct mode) | 20Hz - 20kHz (0.2dB) 1.5Hz - 75kHz (-3dB) |
SNR | Direct mode : 115dB Subwoofer mode : 96dB |
Damping factor (8 Ohm, 100Hz) | > à 1000 |
THD+N | < 0.1% |
Variable low pass filter | 38Hz à 200Hz, 24dB/octave (disengageable LFE) |
Phase inverter | 0-180° |
Supply voltage | 230V 50Hz |
Consumption | 320W Max. |
Weight | 900g |
Package | 1x Atohm S250 module Speaker cable Power cable |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Serge A.
Florent G.
Anthony p.
Florent G.
