Class D Subwoofer Amplifier Module TPA3116 1x50W 8 Ohm
This small Class D Mono amplifier module is ideal for DIY design of a compact, high-performance, low-cost amplification system with very good sound performance. The module is based on an amplifier chip TI TPA3116D2 capable of delivering a power of 50W under 8Ω, while taking advantage of a Class D architecture ensuring a high efficiency of over 90%.
Reference : 14051
19,90 €tax incl.
16,58 € tax excl.
Module Amplificateur for sub
Mono Class D TPA3116 1x50W 8 Ohm
Module Amplificateur Mono Class D TPA3116 1x50W 8 Ohm
This small Class D Mono amplifier module is ideal for DIY design of a compact, high-performance, low-cost amplification system with very good sound performance. The module is based on an amplifier chip TI TPA3116D2 capable of delivering a power of 50W under 8Ω, while taking advantage of a Class D architecture ensuring a high efficiency of over 90%. This power reserve will allow the amplifier to be used with a high-performance subwoofer. Its high quality design ensures low distortion, low noise and dynamic range for a precise and lively reproduction.
In addition, the amplifier also acts as a summing device, thanks to the use of a NE5532P AOP and capacitor tracking. This allows the module to receive a stereo signal and then mix the two channels and finally output in mono, without losing the left or right channel. This function is particularly useful to integrate a subwoofer to different types of signal flow.
Product typeAmplifier Module for sub
InputJack 3.5mm
OutputSpeaker terminal (to screw)
Amplification chipTPA3116D2
Output power (under 24V)1x50W @ 8Ω (THD+N 0.1%)
1x100W @ 4Ω (THD+N 0.1%)
Frequency cut 13dB (20Hz - 200Hz)
Power supply24V DC via Jack DC 5.5/2.5mm (Power supply sold separately)
Total dimensions100 x 61 x 24mm
Weight60g
Package1x Amplifier module
1x Button + nut
InputJack 3.5mm
Amplifier chipTPA3116D2
Power (W)50.0
This small Class D Mono amplifier module is ideal for DIY design of a compact, high-performance, low-cost amplification system with very good sound...
